Unable to Edit existing FGDB with GIS Pro Basic
6157
14
04-17-2019 11:30 AM
ChrisGoessl
We are running into an issue where we are unable to edit existing FGDB on our servers using GIS Pro Basic. We are able to edit the same FGDB using ArcMap Basic license, but unable to do so with the Pro Basic License.
Can someone give me a reason why this occurs?
KoryKramer
Esri Esteemed Contributor
What happens if you export the Pavement feature class to a new file geodatabase?  Can you edit the new one?
AndrewAidt2
I will try it.
AndrewAidt2
That worked. But, why can't I edit it in the previous database? Should I submit a support case?
KoryKramer
Hey Andrew.  I'm glad that worked!  As to why/what is going on with the old file geodatabase, if you want to dig into it a bit with technical support, you're more than welcome.  Just understand that it's probably more likely than not that they will not have an answer for something like this.
You could look into the Recover File Geodatabase tool: https://pro.arcgis.com/en/pro-app/tool-reference/data-management/recover-file-geodatabase.htm (available with a Basic license )
Anyway, looks like it was somehow related to that specific gdb.  Glad you're able to edit that feature class now.
AndrewAidt2
Thanks for your help!
