Trying to create classification ranges from heat map layer using kernel density tool
157
a month ago
DevarsiMajumder
I have gotten a heat map layer that needs to have classification classes either using equal interval or natural breaks method. I read that we need to make a new raster layer from the heat map layer using kernel density method tool. At first the population field was set to none and the  cell size was prepopulated and we got a streak color of purple across the screen. After researching i changed the cell size to 25 and did tests layers at  300 and  500 search radius.  I have attached the images for the finished layer. my question is that did i do this correctly and all that needs to be done is classify the ranges? Thank you
