True Curves Error when Syncing edits in ArcGIS pro
1829
04-13-2023 11:03 AM
RolandDuhaime
I was receiving an error in ArcGIS Pro when I attempted to "Sync" edits of a "Download Map."  The error on the ArcGIS Server logs indicated that it was caused by true curves, even though editing of true curves was allowed on the feature service.  I solved the problem by upgrading from ArcGIS Pro 3.1 to ArcGIS Pro 3.1.1. I hope this helps someone else.
RolandDuhaime
I am now having this same issue in ArcGIS Pro 3.1.2.
RolandDuhaime
Has anyone found a solution to this True-Curves issue? It is still impacting our users.
PatrickZiegler1998
Still an Issue as of Feb 2024... esri..?   Hello..?
