TIN won't load as a 3D layer in my Pro Map
674
03-31-2025 09:52 AM
DylanHinton
I created a TIN layer using contour elevations, but my map scene will only recognize it as a 2D layer. My 3D Analyst extension is covered under my license and enabled. Now I can change the elevation source of the scene itself to the tin,  which gives me some dimension. I really want to be able to vertically exaggerate the tin layer, however, to increase the vertical dimensions of my layer so that the main hill in the data stands out from the rest of the surrounds. Basically, I want to enlarge the size of the hill that I'm trying to display but can't figure out a way to do it since the TIN is only being recognized as a 2D layer.
I was curious if anyone else has had an issue where they created a TIN but it is not recognized as 3D in a scene?
Tags (3)
