Time Slider ArcGIS Pro 1.2?
2631
03-09-2016 08:25 AM
AsmaNKHILI
Hi, i'm trying to do animation based on Time Slider in ArcGIS Pro 1.2. I work on Hermione Ship, i have Time postions, veolcity and direction of ships. I activated Time on feature but data is displayed at evry time and make map unreadble...
How can i display data only at "one time" ?
Please find on attached file a screenshot of data display.
Thanks for help!
Asma
ChelseaRozek
MVP Regular Contributor
On the time slider in Pro, there are two blue "diamonds".
You can drag the left one to be on the same time as the right one, and then you'll only see the points with that datetime as the time slider progresses.
If you left the left blue diamond on the far left of the slider, your data would keep accumulating as the time slider progresses, because you see all the data encompassed by the blue highlighted line on the slider.
I hope that helps
