Taking a Map Offline - License Level Required?
5798
16
01-30-2018 01:13 AM
FinnianO_Connor
To use the functionality of taking a map offline (Take a map offline—ArcGIS Pro | ArcGIS Desktop) what license level do you need? Level 1 or Level 2?
Finnian
FinnianO_Connor
Are you saying a Level 1 role can not be assigned an ArcGIS Pro license?
XanderBakker
Esri Esteemed Contributor
A level 2 named user is required for using ArcGIS Pro. ArcGIS Pro cannot be assigned to a named user of level 1.
FinnianO_Connor
Thanks Xander, this is what I wanted to know.
Finnian
XanderBakker
You're welcome. I'm glad I could help.
RebeccaStrauch__GISP
There may be other options for Pro licensing, for example if you have a concurrent license manager, licenses can may be able to be converted.  You would need to talk to you license administrator to know if this is possible, and maybe your customer service rep or lcal distributor.
ArcGIS Desktop licensing—ArcGIS Pro | ArcGIS Desktop
TimothyKing3
That does not take into account the ability to edit related tables does it?  You would still need Standard or Pro to accomplish that right?
LTK
XanderBakker
When you edit related data in Collector, you will also need a level 2 named user. This is different than with desktop. In Desktop you will need Standard or Advanced to achieve this, but the level 2 named user that one has received with a Basic Desktop license would be able to edit related data using Collector (yet not with Desktop using the Basic license).
