Symbology issue - Polygons
1242
01-08-2023 06:39 AM
NeilGodfrey
Hi - I have polygon and point data in my project. I want to create a map for a document that uses both - however, it is at a fairly large scale (4km) and whilst I can change the size of points to ensure they can be seen clearly, many of the polygons are hard to see. Is the only way to create point data for the polygons  to make this work - or is there a way to make them stand out without increasing their actual size.
Many thanks
David_Brooks
MVP Regular Contributor
This question has been answered here. I highly recommend the workflow in the response to this question:
https://community.esri.com/t5/arcgis-pro-questions/can-you-symbolize-polygons-as-points-using-arcgis...
David
..Maps with no limits..
David_Brooks
David
NeilGodfrey
thank you!
