Symbology Custom Expression - Need to be able to Label Properly
1078
10-23-2019 05:24 PM
JohnDavidson
Question - How can I customize the label values from being 6, 14, 22, 30?
Context:
In using ArcGIS Pro 2.4.1, I wanted to have symbology that represented two attributes at one time. This is possible using a variety of symbology setups, specifically, I did the following:
Created a Primary Symbology using Unique Values as shown below:
Unique Symbology
Then I changed the Vary symbology by attribute tab and used a custom expression to set the unique values to be different sizes based on my expression as shown below:
Set Expression Dialog - Symbology
My symbology of the custom expression has resulted in the below:
Contents Pane
