Symbology changes when changing no. of classes
1646
03-08-2024 06:43 AM
AvaFarouche
Hello!
When I change the number of classes I have in a layer, the symbol squares change from solid color to hatched fill. Has anyone else had this happen? Do you have any ideas why it happens? It doesn't happen every time I do it, but more than half.
I can go change it back if I click on each individual symbol square, go to Format Polygon Symbol, and switch it back from hatched to solid. But why??
I do environmental analysis, so my projects can include many, many layers of graduated symbology that I have to tailor each time for optimal visualization. When this random change happens, I have to change each class in each layer to go back to solid fill.
Thank you!
Ed_
by MVP Regular Contributor
Could be a glitch/bug
Question | Analyze | Visualize
Robert_LeClair
Esri Esteemed Contributor
Whenever I see general strangeness, like this, I recommend doing a soft factory reset to restore core ArcGIS Pro functionality.  You can find the details on how to do this here.
AvaFarouche
Thanks, Robert. I just downloaded Pro onto a new laptop yesterday. It did it on my old one too.
Robert_LeClair
Thank you for the response.  I believe I've found the reason this occurs - there's an FAQ document here that explains the why's.
