Switched to Named User licensing, Python scheduled tasks now only run with Windows user logged in.
1264
9
05-08-2026 08:32 AM
SaraSiskavich
Partial Solution:  So my problem was clearly environmental in that my scripts suddenly began to run normally from the Task Scheduler.  Our MSP did make a number of adjustments in our firewall, the nature of which is unknown to me, unfortunately.
Original Problem:
I have two python scripts scheduled nightly and weekly, respectively, in the Task Scheduler of my Win11 machine outfitted with Pro 3.5.6.   The tasks are set to run under my network account.  Until recently they would run regardless of whether I was logged in or not and regardless of whether or not Pro was open or not.  In Pro, I was consuming a concurrent use license on a license server on our local network.
With the recent mandatory switch to Named User, my two tasks weren’t running at all.  I find I can get them to run normally if I switch back to using my concurrent license server, or with Named User, they will run if I change to “run only when user is logged on.”   Our Portal is ArcGIS online.
There are lot of older threads on and around this topic recommending using single use or concurrent licensing, but that advice is no longer actionable with the deprecation of those license modalities. Recently, there’s a lot of convo about jobs failing due to expiring named user tokens and whatnot, but I don’t think that’s what’s going on here. I’ve tried many times to sign out/back into AGOL with no change in the behavior of the scheduled jobs.
What is the best practice for my scenario so I can run these jobs without a user logged in?  Should I move the jobs off my workstation to a server?  Run them under a service account?  One of my jobs is a nightly compress/reindex of our trad versioned db, the other is a weekly truncate of AGOL endpoints and subsequent append from our on-prem prod db.  So the running context requires authenticating against SQL Server and being the owner of the published endpoints in AGOL.
P.S I don’t have any spare Named User licenses to throw at this problem.
P.P.S  the python runs manually in a python window...no problem with the code.
ThomasHoman
Your best practice forward will involve collaboration your IT department and their security posture.
I had to work with my IT folks to develop an approved service account that could run on a server - we don't allow service accounts on desktops. Some tasks I could copy my connection.sde file for (python db backup into fgdb's) and operate that way. In other cases I had to associate a named user with the service account for some advanced processing tasks.
Hope this helps
CathyAppleton
hi SaraSiskavich,
A co-worker stated:. The user should try “single use license” on the machine he/she is running the scheduled task.
Hopefully that help you.
Cathy
CathyAppleton
sorry, just saw that isn't an option now.     I'll look to see if he has other suggestions.
SaraSiskavich
Please thank your co-worker for his interest.  All our licenses converted to Named User upon our May 2026 software renewal.
BobBooth1
Hi Sara,
You should be able to use named user credentials in a scheduled task, I have several that run on a VM, and one on my laptop that use my named user account.
See this tutorial for a pattern for using a scheduled script, storing your ArcGIS Online credentials in a profile:
https://learn.arcgis.com/en/projects/schedule-automated-near-real-time-data-updates/#:~:text=credent....
Best,
Bob
SaraSiskavich
Awesome thank you for confirming I'm not trying to do something unusual here and that it can be done with Named User.  Signs suggest something in my environment is at play.  I'm still hunting down clues.  And great tip on storing a local profile, will have to try that.
SaraSiskavich
Hi Bob,
I am now able to schedule and run my scripts on our server.  I followed the pattern to store my AGOL credentials in a profile, but my token timed out after ~2 weeks regardless.   This means something is misconfigured, correct?
BobBooth1
I find that ArcGIS Pro licensing expires after a while, so my scheduled tasks can fail, if I don't open ArcGIS Pro on the machine once in a while. I periodically log in to my VM and start ArcGIS Pro, then shut it down to renew the license connection.
Two weeks sounds like the interval people were reporting on this thread:
https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-runtime-error-the-product-license-has/...
SaraSiskavich
Thank you, yes that has been my experience as well.  I might try to add this to my script:
https://support.esri.com/en-us/knowledge-base/how-to-automate-arcgis-pro-launch-and-shutdown-to-refr...
