Summarize Within Add Many Statistics
1077
09-06-2024 07:38 AM
Labels (2)
awagner
Is there a way to select many statistic types in the summarize within tool? You can select many summary fields using the dropdown, but then you have to go one by one to select the statistic type for each field. For this case, I have 50+ fields where I would like to summarize the mean. It would be great if there was a dropdown for statistic type or some way to choose "mean" for all the fields instead of going one by one. Is there a way to do this through the python API maybe?
Laura
by MVP Regular Contributor
I do not not believe there is a built in option to make this any easier. You might be able to make it slightly easier by looking into python api for ArcGIS to perform this.
