Subqueries with branch versioned data
156
a month ago
Labels (2)
AmyRoustCoL
I have a "Pole" point feature class with a related "SignsParksRec" table to store signs on each pole. I created a definition query in the pole feature class in Pro so that only the poles that had a sign in a particular category would display. My query:
FacilityID IN (SELECT Pole_ID FROM SignParksRec WHERE bannercategory IS NOT NULL)
The definition query validates, but when I apply it, there are five poles that do not meet the query and still display.
I've read the documentation on subqueries, but I wonder if I'm running into trouble because the data sources are branch versioned? I know when I do query layers, I have to add where clauses to only return the most recent record and not the archived ones.
RichardDaniels
MVP Regular Contributor
At the simplest level, are you sure bannercategory is actually <Null> in the case of the poles that are showing, but that you believe have no assigned category? Recall, that '' or ' ' is not the same as NULL (the absence of a value). In ArcGIS Pro, you can set a field’s value to null using the Calculate Field tool, provided the field is nullable and stored in a geodatabase.
To set a field to <NULL> you can enter the text None in the Expression box.
