Style a layer by getting the information from its related record.
481
10-29-2025 04:40 PM
Labels (3)
ParnikaPuri
Hi there,
I’m trying to style a layer using information from its related records. The Arcade expression itself works fine, but when I click Done, the expression box becomes blurred and I can’t save it.
I’m currently using a view layer to manage visibility, but since Field Maps doesn’t support views in offline mode, I thought I’d use an Arcade expression instead. Unfortunately, that’s not working either.
Do you have any suggestions or workarounds for this?
Thanks!
Priya_Das
Hi @ParnikaPuri.
Arcade expressions that reference related records are not fully supported for symbology in ArcGIS Online or Field Maps.
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/visualizing-data-from-related-record....
You can preprocess the related data into a field.
