Source was changed but symbology did not update
1206
12-12-2024 08:40 AM
JohnsonAbby
I changed the source of a layer from a polygon feature class to a line feature class; however, the symbology still shows a polygon symbol. The only thing I can find is how to change the outline line of a polygon, but not how to change the polygon to line?
2 Solutions
Robert_LeClair
Esri Esteemed Contributor
So the polygon layer in the Contents Pane still thinks it's a polygon hence the polygon symbology.  I would remove the polygon layer from the Contents Pane and add the the new line feature class from the Catalog Pane to the Map View.  Then ArcGIS Pro will recognize the geometry as a line and provide line symbology options.
JohnsonAbby
Hi Robert,
I feel like I should have thought of that. It worked! Thank you very much.
Abby
Robert_LeClair
JohnsonAbby
Hi Robert,
Abby
Robert_LeClair
You're welcome @JohnsonAbby !  If you feel my answer was correct, you can click the Accept as Solution next to my response to close out this thread.  Happy Friday!
