Sorting the Explore Pop up
687
10-11-2022 06:27 PM
Carolyn_M
Can anyone assist with a query about the Explore/identify pop up.
In ArcMap when using Identify - click on the map and in the Identify Window you can click on the Value column and the values will be sorted. ( Image 1)
In ArcPro when using the new Explore Option to query the map,  the pop up doesn't give the option to sort the value field. (Image2)
Does anyone know if this is possible in ArcPro? ArcGIS.JPGArcPro.JPGArcPro
