sort maps successively in the map frame
1306
12-27-2021 01:20 AM
SalahAjjur
Hello,
Is it possible to successively sort maps in the map frame instead of wasting the user's time looking for the map number? Please see the shot below.
Salah
JayantaPoddar
The easiest way I can think of is to rename the initial map frames (Map1-Map9) as Map01, Map02, Map03, ..., Map09.
This will ensure all the maps are in order in the dropdown list.
Think Location
jcarlson
Definitely the way to go. You may be able to quickly rename them all using a bit of arcpy and regex, too.
aprx = arcpy.mp.ArcGISProject("CURRENT")
for lyt in aprx.listLayouts():
    pad_name = re.sub(r'(?<=Map)(?=[1-9])(?![1-9])', '0', lyt.name)
    lyt.name = pad_name
- Josh Carlson
Kendall County GIS
TomBole
All,
There is a known issue with the sorting of map frames - BUG-000138357 "Alphabetical sorting is not honored in the drop-down menu in the Format Map Frame pane".
Tom
