I'm having difficulties joining a table of zip code data to the Census Bureau's shapefile (tl_2019_us_zcta510). The shapefile has over 33,000 polygons, whereas my client's data contains roughly 24,000, and even then, about 20% of his zip codes are not included in the shapefile. I realize that this is not technically a software problem, and zip codes are changing all the time, but I'm just wondering if anyone has come up with a creative way to solve this problem. Are there any apps to match older zip codes with new ones... ?
Can you get older versions of the zip data? Instead of only looking at 2019 data, see if Census has a archives available.
I'll contact the Census bureau to see if they have older version, but not terribly hopeful. But it's worth a shot.
Thanks!
So, you are working with new ZCTA data:
This statement seems reasonable, i.e., there are more possible zip codes than what your client has collected.
This statement seems off to me:
Are you trying to match on 5-digit codes or 5+4 digit codes?
Perhaps this ZIP Code to ZCTA Crosswalk may be of help. And this page explains a bit about zip codes vs ZCTA.
