Small Pro features I would like to see changed
754
03-07-2019 05:01 PM
BrianKaplan
I've been working on a layout in Pro today and came across the following two program actions I would like to see changed.
1. When working with the legend and adjusting the Word wrapping width or Labels or Descriptions.  If you un-check the box and had changed the width, the width defaults back to 2in.  I would like to see it say at the custom width even though you uncheck it.
2.  cIn a layout with a number of layout items like scale bars, legends, and text boxes, if you select one of these items in the map frame, the corresponding items in the Drawing Order Contents Pane are highlighted. However, if you group all these layout items together, selecting an item in the layout frame ends up selecting the group name and not the specific element in the group.  I would like to see the individual item in the group selected in the Contents pane.
Is this the best forum for these recommendations
Thanks
Brian
Tags (1)
DanPatterson_Retired
ArcGIS Ideas‌ is the usual spot to make suggestions or to check if this has been an already reported suggestion
