sharing vector tile layer
1964
03-20-2017 01:42 AM
fredzavuga
 am following the option of allowing arcgis onlin to create the tiles from my map (web layer) created in arcgis pro,  the option of creating the tile package before publishing failed me as i see the tool is disabled (must have run a tool successfully..to have it enabled).
Tags (1)
JayantaPoddar
Check for any unsupported layer type in TOC. Try following the steps as stated in Author a Map for Vector Tile Creation.
Think Location
fredzavuga
Thanks for quick response, i only have the openstreet map and world navigation map, id think these are already vector tile layers. even if remove either error remains. is there a way of confirming supported maps?
