Sharing joined and related attribute table from ArcGIS pro to portal failed!
1020
03-25-2019 05:19 AM
AyokunleAdebisi
Sharing joined and related attribute table from ArcGIS pro to portal failed! in ArcGIS Pro  I am trying to share a my attribute data which is as a result of joining and related tables to portal but it failed. when I checked online it requested me to remove join and relate before i can share. However I need these attributes. Please what should i do.
by Anonymous User
Not applicable
Hi!
You can use relationship classes instead of relates to make relates permanent and not in-memory which will allow it to be published.
https://pro.arcgis.com/en/pro-app/tool-reference/data-management/create-relationship-class.htm
Hope this helps!
AyokunleAdebisi
Thanks will try that,
