Sharing custom basemap to ArcGIS online from ArcGIS Pro.
2597
06-24-2024 04:40 AM
HardikVarshney
Hi Everyone,
I have created a custom basemap in ArcGIS Pro by following the steps given in this article (Basemaps—ArcGIS Pro | Documentation).
The map got converted to a basemap and started to appear in basemap dropdown.
Now I want to share this basemap to ArcGIS online. Can someone suggest a way for achieving this.
CodyPatterson
MVP Regular Contributor
Hey @HardikVarshney
I found this article here that may be helpful: https://doc.arcgis.com/en/arcgis-online/create-maps/choose-basemap-mv.htm
As a summary, you will need to share this map to AGOL from Pro and match the considerations that are in the "Considerations" section within the document. I have many that I uploaded as Map Image layers, regular Feature Layers will not work with this method. The instruction will be in this section "Use a basemap that is not in the gallery".
Hope that helps!
Cody
