Set Pro's default settings programmatically?
2534
7
05-20-2024 11:33 AM
AlfredBaldenweck
MVP Frequent Contributor
Is it possible to set Pro's settings (e.g. default project save location) programmatically (Read: through code)?
Thanks!
Robert_LeClair
Esri Esteemed Contributor
Yes, you I believe you can do this using the workflow described in this Esri Technical Support document.  Not necessarily Python code but there is code involved in the user.config file.
AlfredBaldenweck
This is a great start! The other setting I'd look to look for is changing the default Package unpacking location. I don't seem to be able to find it in that config file; is there another place I should look?
Robert_LeClair
Yes, in ArcGIS Pro itself, go the Project->Options->Application group->Share and Download tab and you see many options for Staging, Unpacking of packages, templates, files and offline maps.  There is a radio button you can click "Ask where to save before unpacking" that you can set too. If you accept application defaults, they always go to your C:\Users\user_profile\Documents\ArcGIS Pro\Packages directory or others seen in this pane.
AlfredBaldenweck
Yes, I'm hoping to do this without having to open Pro itself so I can apply these settings for multiple users. Is there a file outside of Pro that I can mess with to make this happen?
Robert_LeClair
Hmmm...not sure.  @KoryKramer - are you aware of a file that can be modified outside of the Project->Options to set a default package output location?
KoryKramer
@AlfredBaldenweck read through this https://pro.arcgis.com/en/pro-app/latest/get-started/application-setting-management.htm
The workflow is designed for admins who want to set (and optionally lock) settings and deploy those to multiple machines.
AlfredBaldenweck
Thanks, Kory and @Robert_LeClair ! I'll give this a look.
