SelectLayerByLocation_management fails for unknown reason
2487
09-02-2021 09:50 AM
Labels (3)
ChuckBenton
I have an ArcGIS hosted feature layer, and want to make a selection based on a lat/lon. The last line is generating an error:
RuntimeError: Object: Error in executing tool)
I can't identify what I'm doing wrong. All is in WGS84. Here's the code
import arcpy
from arcgis.gis import GIS
gis = GIS("https://www.arcgis.com", "XXXX", "XXXX")
append_layer_itemid = '33518827e9e24defbacd671bfd26XXXX'
#Grab the layer
fs_item = gis.content.get(append_layer_itemid)
fs_layer = fs_item.layers[0]
#make a layer with the points
arcpy.env.workspace = r"C:\Users\cbent\OneDrive\Documents\ArcGIS\Projects\MyProject\MyProject.gdb"
arcpy.MakeFeatureLayer_management('points_layer', 'point_layer')
arcpy.SelectLayerByLocation_management(fs_layer,'INTERSECT','point_layer')
It's the last line that's failing, any ideas?
Chuck
ChuckBenton
Changing fs_layer in arcpy.SelectLayerByLocation_management(fs_layer,'INTERSECT','point_layer') to "https://services8.arcgis.com/2G8bTpCps4vdRut5/arcgis/rest/services/ParcelAtlas_V2_4/FeatureServer/0" fixed the issue. Basically had to use the service URL directly.
DanPatterson
it may be failing here
You might want to use arcpy.Exists  to confirm the existence prior to select by location.  It would also be a good idea to check both layer coordinate systems while you are at it and bail if they differ
... sort of retired...
ChuckBenton
 The online Parcel Layer is in WGS_1984_Web_Mercator_Auxiliary_Sphere (WKID 3857). Earlier I did have the point layer in a different WGS 1984 WKID, which has been corrected.
I now print the point_layer WIKI and bail if it isn't 3857. I also confirm it exists. Still seeing the same error:
. Any suggestions?
ChuckBenton
