select the 3 features that have the largest attribute value
3115
08-17-2020 06:12 AM
IanIrmischer
I need to select the 3 features that have the largest attribute value. How is this best completed? I would like to do this within a model builder environment. I have been trying to figure out the sql statement within the select tool but am having syntax problems.
Katie_Clark
MVP Regular Contributor
Have you seen this post? Might be helpful...
arcgis desktop - Using Select Layer By Attribute to return top 3 records - Geographic Information Sy...
As the post states, "Python scripts in the form of custom tools can be used in Model Builder".
Hope that helps at least a bit! Good luck!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
IanIrmischer
Thanks Katherine, I did see that. Just figured that since it seems like such an important query that ESRI would have a tool. Guess not.
JoshuaBixby
MVP Esteemed Contributor
This is yet another example of where Esri has done a poor job of implementing SQL support in the file geodatabase.  If your data were stored in just about any other database, the query would be quite trivial, but doing something simple like this is way more complicated than it needs to be because Esri doesn't support TOP, LIMIT, or similar keywords.
KoryKramer
Esri Community Moderator
Bud
Legendary Contributor
