Select features from layers added from a map service
1246
08-09-2024 10:23 AM
JoseSanchez
Good afternoon,
Is there a way to select a line or a point form a layer added forma map service in ArcGIS Pro? I added a map service to a web map, imported the web map in my ArcGIS Pro and now layers that are in the map service cannot be selected.
I am only able to see the popup window
Dan_DMR
None that I'm aware of. You can contact the content creator and ask for the shapefile or gdb
Ed_
by MVP Regular Contributor
I think if the same feature class is published as a feature service then you can
Question | Analyze | Visualize
mikaljohn
You might need to enable the selection by setting the layer to be selectable in the Contents pane. If that doesn’t work military belts, try exporting the map service layer to a feature class to make it selectable.
jacobmark51
You might need to check the layer's properties in ArcGIS Pro to ensure that selection is enabled. Sometimes, layers from map services IDM Cracked have selection disabled by default, so adjusting these settings can help.
