Select by Attributes Updated after hit the saved pending list with the dialog box ?
526
06-09-2025 09:48 AM
DEAF_PROBERT_68
Honored Contributor
I have a question that I am not sure if it has been resolved or question in the past... but when I was working on a layer that has all the symbols for the roads....
I use the select by attributes and see there was a problem...
I wrote down on my paper when I saw there is an issue, I am seeing...
Using the "Select By Attributes" under the Map tab and then in the selection group options.
  1. When you create a new field to calculate or assign from another field or copy from another field on your layer.
  2. Open the Select by Attributes.  Use the new Field to use your clause to create your query expression.
  3. When you enter the apply button after you made the clause. Open the Attributes pane in the selection and you see the features has been selected.
  4. You assigned or input your field you need into the field database.
  5. When you are done, you save the edit inside the "Select by Attributes" dialog pane or "pending" save.
  6. You then go back to the "Select By Attributes" again and click on the 3rd box aka values or fields to see if the values have been updated or not.
  7. It does not update the field when you made the changes
You would have to constantly have to use exit the Edit button and then come back into the Edit again  to see the changes are updated.
Why does it not update and it should have been update immediately ?
