Save Output in Table without overriding
1899
06-29-2023 05:12 AM
TimThiele
Hello dear ESRI community,
I have a problem with creating a table in ModelBuilder.
The ModelBuilder should:
For each individual circular-area, give out the number of locations only inside the area (image 1 green dots) and save the sum of all attributes for CO2 into a new table.
The code (see image 2) works for a single area and I have already set an iteration right at the beginning of the code. but I think that after the sum statistic, the table is created but the column is overwritten after each iteration.But I would like to save each iteration step as a separate row in the output table.
Question:
How do I save the result as a new row in the table after each iteration?
Is there a tool or a basic method to implement this?
Image 1:
Image 2:
TonyContreras_Frisco_TX
Model Builder includes an Iterator element that can used in this situation. Only one iterator can be used in a model.
TimThiele
Hi Tony,
This is also executed, however I would like to save each iteration step as a separate row in the output table.
Raul_Jimenez
Thanks @TonyContreras_Frisco_TX and @TimThiele for your help here!
I think this questions is better suited for ArcGIS Pro Questions. I'm moving it there.
