Save Edit Error: 504 Proxy Server Bad Address - Timeout
4896
11
07-14-2023 01:11 PM
GregReinecke
Hello All,
I am running the latest build of ArcGIS Pro on a Windows 10, Dual Xeon CPU with 64GB of Ram. When I download my map from AGOL in ArcGIS Pro , select 48k points, delete them all looks fine. But when I then Save Edits after about 60 secs or so I get this error.
If I delete small numbers of points and Save Edits I don't get this error. Could there be some config params I have overlooked or am I not working as locally as I think? I find it unlikely Pro doesn't all the deletions in bulk.
Thanks in advance.
GR
TomKukitz
Sorry for getting a little testy, I have been dealing with support services on this and it has been plaguing me for over two weeks. I have resorted back to ArcMap and Pro 3.0 for now and don't think I will upgrade to 3.1 until the version after 3.1 comes out. I am perfectly happy with ArcMap, but need to upgrade my license to advanced. Pro Layout does make things easier for paper/pdfs, but ArcMap and Attribute Assistant together are awesome!
Thanks for the reply and again please accept my apologies! My patience is getting thinner as I get up in age. 😞
Robert_LeClair
Esri Esteemed Contributor
No problem Tom - I understand as I've been working with Esri technologies since 1992!  ArcInfo Workstation 5.0!  So I've experienced the headaches from transitioning from Workstation to ArcView*GIS to ArcMap to ArcGIS Pro!  I'm glad it's working for you now!  ArcGIS Pro 3.2 is scheduled to drop sometime later this year so hopefully workflows improve and BUGs diminish...
