Restricting feature export in ArcGIS Pro
599
01-23-2026 06:42 AM
Labels (2)
wanderer1
A service needs published that will be consumed in ArcGIS Pro 3.x through a custom Add-In
Within Pro:
  • the user needs to be able to Select features on the map
  • query features
  • The user should not be able to export features from the service ( VERY IMPORTANT)
  • The user does have access to the username and password for the service
  • These features are read only, no editing required
  • Want to use OOTB tools such as attribute tables, querying, selecting as much as possible to avoid building custom functionality
Looking for a way to accomplish this above without a managed configuration as the user still has access to full pro.
As a workaround to limit the number of features exposed to the user at once and make it more difficult to obtain the entire set of features, we are looking at creating a custom service where an extent and some parameters are provided and only a subset of features will be returned.
The service would provide geometry and attributes separately.
In the Addin
  • Geometry would be drawn as graphics on the map.
  •  Attributes would be held in memory
  • Graphics to Features still allows exporting of the graphics but they will not have attributes and would only be a subset of features. This is not a perfect solution but better.
  • Alternatively using AddOverlay for the graphics, we believe the layer will not be in TOC and neither geometry nor attributes could be exported?
  • Need to manage graphics now when extent changes, user changes query – not ideal
  • Can’t use out of the box tools for querying as attributes need to separate from features – not ideal
Is there an alternative way to achieve this desired result? The service could be published in enterprise or ArcGIS Online.
AyanPalit
@wanderer1 There are many configuration options for Map/Feature service.
Review the  service publishing configuration options and choose the appropriate parameters per your requirements.
For e.g. Feature service > Step 6 mentions the option to enable/disable export data.
Ayan Palit | Principal Consultant Esri
AyanPalit
