Required field parameter not working
1785
04-10-2025 08:00 AM
Labels (3)
ChaceCarpenter
I created a feature class with  a required field, but there is an issue. When I add a feature and I don't fill this field; the system lets me add the feature even though the required field is empty. I want any feature that is added to the data set to always have this field filled for data quality reasons. Ps, I am working in a local geodatabase if that matters. It seems that making a field required only makes it so the field cant be deleted. Is there a way to prevent the creation of a feature if a field isn't filled?
Robert_LeClair
Esri Esteemed Contributor
There's a couple workflows that would get you close:
1.  You can configure the feature template to prompt for attributes on 1 or more attribute fields.  Unfortunately, this would still allow for NULL values.  Configure a feature template—ArcGIS Pro | Documentation
2.  If features already exist in the feature class to be edited, you cannot uncheck the "Allow Nulls" item in the Fields Designer  FAQ: Is It Possible to Uncheck the Allow NULL Check Box When Editing the Attribute Table i
3.  If you can recreate the feature class with no data in it - then yes, you can configure a field to not allow NULL values - Problem: Unable to Configure Fields to Ensure Null Values Are Not Allowed in ArcGIS Field
4.  You could create a constraint attribute rule that does not allow for Null values - Attribute rule script expression examples—ArcGIS Pro | Documentation
DanPatterson
short of doing a query on the required field for any value that is not None and using the GetCount tool (which should return a 0 value if there is nothing there)
Get Count (Data Management)—ArcGIS Pro | Documentation
The question becomes, why do you want a required field prior to creating a feature and putting a value in it?  Perhaps elaborating on the requirement would help
... sort of retired...
ChaceCarpenter
I want to make sure others users cant add a feature without filling this field. Its a field that should never be blank. So I was trying to validate the data that other user may enter into the dataset
Robert_LeClair
ChaceCarpenter
Thanks! I went with workflow 4
