Replace Geometry in ArcPro (bulk)
904
06-24-2020 09:58 AM
RichardPaola
I have a base layer in which i need to update a selection of parcels with corrected geometries.  I have already created the layer containing the correct geometries. (about 1000+ records).  In ArcPro, using replace geometry prompts you to select the parcel in question requiring changes, then to digitize the correct points.  Rather than digitizing, i want to simply select the correct polygon, ie. 2-steps, select original, select correct, update geometry.  Seems this command does not allow this?  Any better method ?  (rubber sheeting, geometry adjustments, etc?)
