Removing ocean textures from Imagery basemap
2319
10-25-2022 01:35 AM
ChristofferLindellBolin
Hi, I am trying to remove the ocean textures for the Imagery basemap in ArcGIS Pro and I have tried it with using a vector tile layer, although have not been able to export it.
When I try to create a map tile package in ArcGIS pro, I get the error "Layer type is not supported: Map/World Imagery (for Export)".
This is my Drawing order:
I have been using this map https://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Imagery/MapServer as the basemap.
And the following style: https://kockums.maps.arcgis.com/home/item.html?id=8f4fde8063d04a1bb17824073d9a99dd
Thankful for any help.
Tags (3)
AlfredBaldenweck
MVP Frequent Contributor
Try using the Vector Style Style Editor to change all the bathymetry to the same color, Save As, and then use that as basemap.
ArcGIS Vector Tile Style Editor
I've been doing that but I can't seem to be able to export the vector tile layer combined with the world imagery as a tpk or tpkx. I then get the following error:
My intention is to combine the world imagery with a vector tile layer that hides the ocean and later export it as a tpk or tpkx file so that I then can load it in Unity.
AlfredBaldenweck
Sorry, I didn't read closely enough.
So, I've attempted it several times myself, and it looks like Tile Packages don't like Imagery Layers.
