Rectangular Pairwise Buffer
2110
03-01-2023 09:48 AM
saldanax
Hi all, I need to use the pairwise buffer tool, but need the output to be a rectangular and not circular. I've looked through the pairwise buffer documentation, but can't seem to find what I am looking for. Any advice on other tools to use or how to proceed? Thank you!
Tags (1)
DanPatterson
MVP Esteemed Contributor
If you are using points...
How To: Create a square buffer around a point feature (esri.com)
the process works for Pro as well and doesn't require coding
... sort of retired...
DanPatterson
SergeyTolstov
There is also Graphics Buffer Tool. With the option Caps = square it will generate squares around points. You can also use it to make squared buffer around lines and polygons.
