Raster to Polygon fail
3762
08-05-2019 03:54 PM
NaomiBegg2
I'm trying to do change a raster to a polygon so that I can use the select by location tool.
When I first tried to use the Raster to Polygon tool it failed and gave me the error message:
Error: 000864: The input is not within the defined domain
I tried to follow all the instructions in this article:  https://support.esri.com/en/technical-article/000011393
I used the times tool to multiply my raster by 10 then I ran the Int tool.
My next attempt to use the Raster to Polygon tool with this new int layer resultd in the generic Error: 999999 something unexpected cause the tool to fail
How do I get around this?
Is there another way to select polygons that are intersected by this raster?
DanPatterson_Retired
Did you export the Int portion of the workflow as a *.tif into a folder that contains no spaces in their path?
Usually it is something to do with filenames and/or paths... ie c:/temp/some.tif
NaomiBegg2
Thanks for the suggestion.
I have re-run the int tool and made it outside my file geodatabase.
Now the raster to polygon tool has worked.
