Raster to Point - Converting Multiple Files at a Time
8474
15
01-10-2022 03:11 PM
ScottFraser_Key-West
I've got about 200 DEM LiDAR raster files. Using the "Raster to Point" tool easily converts the cell data to points, but it'll be a slow process if I have to convert every file individually.
Is there a tool in Pro that'll allow me to select multiple raster files at time for point conversion?
DanPatterson
MVP Esteemed Contributor
that was suggested earlier with possibilities to code it... they have a large number to process so manual selection would be out of the question
... sort of retired...
SteveLynch
Rather than have all the rasters in the map, you can browse to the rasters and using shift click select first and last. This is much quicker than manually adding them.
Didn't seem to allow shift-click on multiple files. Would only accept one at a time. However, the suggestion of batching them via the right-click is much more efficient.
thanks,
SteveLynch
 click on the first raster and then shift click on the last raster
Just figured out how to do what you suggested about selecting multiple files. I'd been trying to select multiple files from within the "Batch Raster to Point" pane.
Then it dawned on me, multiple files can be selected in the "Contents" panel and dragged to the "Batch Raster to Point" pane and they'll be added to the batch. Ah ha!
As my father used to say:  "Finally, light dawns on Marble Head."
thanks
Oh yeah... much easier. Wasn't aware there was a batch option hiding under the right-click.
Thanks Luke.
