Raster calculator: excluding no data pixels
3438
11-06-2019 08:13 PM
EyalSaiet
In ArcGIS Pro, is there a way in the Raster Calculator to exclude the no-data pixels that are defined in my raster as 65535? I see there is a mask option, is that my only option is to create a mask?
Failing to do so converts the 65535 to a float number which then I cannot select as no data in symbology as you can see in the atached document.
EyalSaiet
Can anyone in ESRI respond to this question?
thanks
KoryKramer
Esri Esteemed Contributor
Here I mocked up a raster where nodata values are 65535
Use Reclassify—Help | ArcGIS Desktop (either Spatial Analyst or 3D Analyst) to reclassify those cells to NoData:
Does that work for you?
