"Loading locators..." pop-up window
4973
7
01-01-2021 05:40 AM
RasheedKhaleel
I am running ArcGIS Pro 2.7
I walked away from my computer, no geoprocessing events running, just a dormant moment.
When I returned, this window had popped up
 Loading LocatorsLoading Locators
Don't know what it is or what triggered it, but can't make it stop without breaking the program. I don't think I would lose too much work, if any, but I'd like to identify what caused it and how to not repeat this interruption. Thanks in advance
BenClark
Do you host any previously used locators on a different machine? Wondering if a temporary service disruption there would cause some kind of automatic refresh in an otherwise dormant client session.
Very strange though!
Robert_LeClair
Esri Esteemed Contributor
One question - how many Locators have you (or your administrator) set up for your ArcGIS Online/Portal?  For my Locators in the Catalog, I have 3 by default I believe.
Nathan_T
I'm having the same problem.  Pro 2.7, with the latest patch installed today.  Loading locators randomly popped open and I cannot close it, or do anything else in Pro.  I'm 30 points in to a very challenging georeference and having to kill the program will be very very painful.
RasheedKhaleel
I did not have any Locators running except the default ArcGIS Online one. I was not even doing locator work at the time, but I did have to kill Pro unfortunately. I have not had this same problem again, though. Nathan_T I feel your pain!
MarkJennings
Everytime I do something this comes up and slows things down.  How do I remove the Locators so this doesn't happen?
Joel
Pops up constantly while editing. Hideous
Robert_LeClair
Joel - sorry to hear that you're experiencing this pop-up.  It's definitely not expected behavior.  I would recommend running a Soft Reset of ArcGIS Pro as documented here to see if this fixes the issue - How To: Perform an ArcGIS pro Soft Reset
