python
1662
03-24-2020 05:08 AM
KalSsin
Hi~~~~
This is the listfield. What did I do wrong?
import arcpy
featureclass = "C:\EsriTraining\ProVectorTiles\Create\SANDAG_Geology.gdb\Geology"
field_names = [f.name for f in arcpy.ListFields(featureclass)]
arcpy.featureclass = r"c:/data/municipal.gdb/hospitalsC:\EsriTraining\ProVectorTiles\Create\SANDAG_Geology.gdb\Geology"
arcpy.featureclass = r"C:\EsriTraining\ProVectorTiles\Create\SANDAG_Geology.gdb\Geology"
import arcpy
  File "<string>", line 4
SyntaxError: unexpected EOF while parsing
arcpy.featureclass = "C:\EsriTraining\ProVectorTiles\Create\SANDAG_Geology.gdb\Geology"
  File "<string>", line 2
import arcpy
field_names = [f.name for f in arcpy.ListFields(featureclass)}
SyntaxError: invalid syntax
import arcpy
field_names = [f.name for f in arcpy.ListFields}
DonShawEsri
A few things are going on here. In the last example, you ended the ListFields function with a } instead of starting it with a  (. You should try setting the work space for your data. The code below works for me (Python 3). Make sure you are using the correct version of Python for things like the print statement.
import arcpy
arcpy.env.workspace = 'C:/data/earthquakes.gdb'
feature_class = 'earthquake_points'
field_names = [f.name for f in arcpy.ListFields(feature_class)]
print(field_names)
DanPatterson_Retired
 [f.name for f in arcpy.ListFields]
[ must match ]  left and right brackets
DonShawEsri
import arcpy
print(field_names)
KalSsin
Thank you for your kind example.
I finally made it.
