Python Script to Auto update Web Map from Arc Pro project
107
yesterday
ShareUser
Esri Community Manager
I would like to create a python Script to automatically update my web map from my ArcPro project.
I have a ArcPro project that I manually update the web map right now.
I also used experience builder to create a user-friendly web map that uses the data from my published web map.
I have attached my first try at a script, but it doesn't work. Any help on how to fix the script would be appreciated.
ShareUser
Try arcpy.server.UploadServiceDefinition(sd, portal_url)
Double check you are signed in
print(arcpy.GetActivePortalURL())
Change raise Exception(f"Map '{map_name}' not found.")
to
sddraft = os.path.join(sharing_draft_folder, f"{service_name}.sddraft")
sd = os.path.join(sharing_draft_folder, f"{service_name}.sd")
print(f"{service_name} published successfully!")
And for the Exception try,
except Exception:
print("Publishing failed.")
print(arcpy.GetMessages(0))
print(arcpy.GetMessages(1))
print(arcpy.GetMessages(2))
raise
