Publishing with a rotation
1056
08-18-2021 07:30 AM
BrendanMcCann
Hi all, I was wondering if anyone could point me in the right direction when it comes to publishing a map on ArcGIS pro with a rotation edit. I know the map can be rotated when in GIS but when I go to publish the map with the rotation property edited, it does not work. Is it possible this can be done?
RPGIS
by MVP Regular Contributor
Yes. So you can either do a manual rotation based on a map series and using the feature class with a rotation field to orientate the map accordingly, or you can rotate the map manually by changing the map orientation.
