Publishing A Local Web Scene
731
06-01-2023 07:57 AM
MorganJenkins2
Cheers all. I am having some trouble viewing my data when publishing a local web scene. Ive been learning the workflow and get no errors during analyze or in the web scene viewer, however some of the layers are not drawing. All the coordinate systems match, the data is all coming from a registered data store on SQL server, the layers that do load are working properly with the elevation surface in ArcPro and in the web scene.
I started with something simple: an elevation source, imagery, a building multipatch, and waterbodies polygon.
Everything is rendering except the z-aware polygons and polylines. Also, we published the entire datastore to our internal portal and when I bring the same features in using MapImage layer it works perfectly, but when I bring it in as a Feature layer I get the same issue as if I published it from ArcPro, it does not render.
I made sure the visibility range was set appropriately, I tried all the different property/symbology settings, and I tried publishing it as both a 2d and 3d layer. I am at a loss for what else to try at this point.
Any help would be greatly appreciated. Thank you!
Edit: I found some very old posts saying that polylines/polygons are not supported? Is this still the case? It seems these are the only feature types giving me a problem
