Publish python script containing umlauts as a Geoprocessing Service to ArcGIS Server via ArcGIS Pro is cut off
1498
11-15-2022 06:01 AM
geowind
Hi everyone,
when I try to publish a python script containing umlauts as a Geoprocessing Service to the ArcGIS Standalone Server via ArcGIS Pro, the publishing process is successful (no error/warning), but the published script is cut off at the first umlaut.
The script I'm publishing:
import arcpy
# Hello Wörld
arcpy.AddMessage("Hello Wörld")
The published script ("\directories\arcgissystem\arcgisinput\TestPublishGP.GPServer\extracted\p20\testpublishgp\TestPublishGP.py") looks like this:
import arcpy
# Hello W
If I publish the same script via ArcMap 10.8.1 everything works just fine. We're switching to ArcGIS Pro, so using ArcMap is not an option.
ArcGIS-Server: 10.9.1
ArcGIS Pro: 2.8.6
Python: 3.7.10
How can i solve this problem?
JohannesLindner
Does it work if you specify a coding that works with umlauts?
# -*- coding: cp1252 -*-
import arcpy
# ÄäÖöÜüß
arcpy.AddMessage("ÄäÖöÜüß")
Have a great day!
Johannes
geowind
Hi Johannes,
thank you for your suggestion. I tried your script and unfortunately it didn't work.
import arcpy
# ÄäÖöÜüß
# -*- coding: utf-8 -*-
import arcpy
Interestingly he changes the encoding string during/after the publishing process to utf-8.
I am surprised that the comments aren't ignored. (The script is cut off at the first umlaut in the comment in line 4).
Greetings
geowind
PS I don't know why this post has extra paragraphs at the end, I can't remove them 😀
