Project raster - cell distortion
1400
11-20-2023 05:23 PM
Greta
Hi
I project a raster from a projected coordinate system to WGS84. I tried the three methods provided by the tool "Project Raster" and kept the cell size of the original raster, but it always slightly distorted the cell size.
Can we project the raster without distorting the cell size?
Greta
DanPatterson
required reading
Cell Size Projection Method (Environment setting)—ArcGIS Pro | Documentation
How the Cell Size Projection Method environment setting works—ArcGIS Pro | Documentation
current default to give you some guidance is
When projecting from GCS to PCS, or PCS to GCS, the output cell size is calculated based on the average of the ratios of the four sides and the two diagonals of the projected extent to the original extent. This is the default.
... sort of retired...
DanPatterson
required reading
