Problems in 3D Softmouse configuration
936
05-14-2024 06:21 AM
JairoCordero
Hello to the entire Community.
I want to work with 3D Stereo models for photointerpretation, I already managed to build the entire model and now I have problems with the Softmouse configuration.
I don't know how I can work with it and start editing the polygons.
This is the default configuration that ArcGIS Pro gives me, but when using it, for example, I cannot divide the polygons using the Softmouse and I have to use the normal mouse.
By using the buttons you only create a shortcut to the tools.
In ArcMap it allows me to work and edit polygons with the softmouse, I thought it would be the same in the Pro.
I hope you understand and can help me solve this problem.
Kind regards.
