Problem with gpkg in Arcgis pro
2141
10-18-2022 02:28 AM
Labels (2)
MariaSomma_
Hi I have a problem with a gpkg file.
When importing a feature class it does not give me the option to add fields in the attribute table and I get the text: This command is currenty unavaible. The project has unsaved edits or the table or its schema is read only.
The project has just been opened and I have not made any edits.
Also, if from the gpkg clicking on the feature I press "open table," in that case, it makes me add the table to the project and makes me add new fields.
What could have happened? it is really problematic not being able to work directly with the tables inside the map but having to open them externally each time.
Before I upgraded to Arcgis pro 3.0.2 I did not have this problem.
Who can help me?
Thank you very much
Translated with www.DeepL.com/Translator (free version)
nadja
have you ever found a workaround? i've got the same problem with arcgis pro 3.5.2 and a geopackage that I created and feature classes which i imported in that gpkg. and there are no open edits or anything. it's really strange.
