Pro 3.0 UI Bug? FMV aircraft location, FOV, and frame center symbology show random colors
721
07-08-2022 03:03 PM
by Anonymous User
Not applicable
FMV aircraft location, FOV, and frame center symbology appear as random colors. Symbology changes are not updated or respected when changing the Color option in the Video Player.
Steps to Reproduce:
- Start a blank project and add a Map.
- Add an FMV video to the TOC.
- Change the Color option in the Video Player window.
- Play the video for a few seconds to verify the correct color was used.
- Remove the FMV video from the TOC.
- Add the same FMV video back to the TOC.
- The aircraft location symbology is now a hollow fill black circle. The frame center symbology is now a hollow fill triangle. The FOV and line of site to the frame center are now random colors. The symbology will not change or revert when the Color option is changed in the Video Player.
Workaround is to simply never remove a video from the TOC or restart Pro when encountering the bug. But these options are inconvenient.
