Print Layout from Pro without defaulting to Map Series
610
02-26-2020 07:13 AM
RobertBorchert
Honored Contributor
I am trying to create a PDF of an area for a underground locate. I have Map Series set up for all of our substations.
For some locates I want to navigate to the area in question by using Map Series and then zoom in a little tighter to show better detail.
And I want to print out what I see.
Is there any way or setting to not have the Share task default to going to the extents of the Map Series.  Without having to create a new polygon or redefine the Map Series.
Tags (1)
Roos_Scholten
I have the same question. Did you ever figure out how/if this is possible?
