Possible Summarize Within Bug- Tool not recognizing dataset selection
313
05-11-2026 07:23 AM
vlabrie
I recently updated to ArcGIS Pro 3.6.2, and since then, the Summarize Within tool does not recognize when I use selected records as the Input Summary Features. For example, I made a selection of a Land Use Land Cover dataset to run Summarize Within to determine the area of a specific land use on a property, but the results show as if I used the entire dataset and returns the total acreage of the property. I tested exporting the selection and running the tool using the exported dataset as the Summary Features and that produced the correct area. Is anyone else running into this issue?
(I also just updated to 3.6.4 to see if it would fix this bug but no luck.)
Robert_LeClair
Esri Esteemed Contributor
@vlabrie  - I see that you submitted an Esri Support ticket this week.  Was the analyst able to resolve this item?  Please advise.
