Pop-up's Toggle button
1524
11-21-2024 11:52 AM
Head_In_The_Clouds
What is the toggle button in the pop-up pane designed for? Please see screenshot:
Does anyone use it?
Cheers,
Cloud
BarryNorthey
"When displaying feature layers in a map or scene, you can identify attribute information about a feature without making a selection or interfering with an existing selection by opening a pop-up."
You can use the selection toggle to select the identified feature if you want.
BarryNorthey
Head_In_The_Clouds
Ah right. using select makes the features appear in the Attributes pane. Thanks!
DuncanHornby
MVP Notable Contributor
Also leave your cursor over it and it tells you exactly what it is!
