Polygons dissappear after calculating geometry
615
04-24-2026 06:03 AM
TrygSolberg
ArcGIS Pro 3.5.0. After creating polygons in an existing feature class, they are visible after saving them. When I go in the attribute table and calculate geometry, the polygons disappear from the map.
DanPatterson
MVP Esteemed Contributor
run check geometry or repair geometry on the featureclass when you are not editing
maybe the rings are reversed
Check Geometry—ArcGIS Pro | Documentation
... sort of retired...
AlfredBaldenweck
MVP Frequent Contributor
Possibly just a graphical bug; do they appear if you re-add the data to the map or refresh?
Robert_LeClair
Esri Esteemed Contributor
What type of symbology are you using?  Single symbology or other?
